What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Page 1 of 3 123 LastLast
Results 1 to 20 of 60
  1. #1
    Join Date
    Oct 2008
    MN
    Posts
    82
    Thanks Given
    Thanks Received:
    MAINT Slip and VDC Off Lights?
    So went to lunch today and right after shifting into to Drive my Slip light and VDC Off lights come on. Stop at the restaurant and start the car back up and the lights are off again.
    Just wondering what causes this? Going to be bringing the FX in soon to the dealer so want what ever it is fixed prior to the warranty expiring...
    Thanks
    See More: Slip and VDC Off Lights?
    Register
  2. #2
    Join Date
    Jun 2007
    Los Angeles, CA
    Posts
    12,628
    Ride
    2005 FX35 RWD
    Thanks Given
    108
    Thanks Received:
    143
    Were you driving it hard or with a heavy foot prior to the light? I have the same problem at times with the stuck light.
  3. #3
    Join Date
    Oct 2008
    MN
    Posts
    82
    Thanks Given
    Thanks Received:
    Not really no, on my way in I pushed it a little, nothing major...Then went out to go to lunch, probably 4-5 hours later and the first thing I notice is the Slip and VDC Off lights on. Literally put it in reverse and barely hit the gas to start moving and it came on...
  4. #4
    Join Date
    Jun 2007
    Los Angeles, CA
    Posts
    12,628
    Ride
    2005 FX35 RWD
    Thanks Given
    108
    Thanks Received:
    143
    Not the same problem as mine. Yours sounds way more sensitive.
  5. #5
    Join Date
    Oct 2008
    MN
    Posts
    82
    Thanks Given
    Thanks Received:
    I will let you know what I find out at the stealership next week...
  6. #6
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    no red brake light at the same time with the slip & vdc lights?
  7. #7
    Join Date
    Jun 2007
    Los Angeles, CA
    Posts
    12,628
    Ride
    2005 FX35 RWD
    Thanks Given
    108
    Thanks Received:
    143
    Not I, solo VDC . . & it's sporadic . . not like I'm riding with it lit all the time
  8. #8
    Join Date
    Oct 2008
    MN
    Posts
    82
    Thanks Given
    Thanks Received:
    Nothing but those two lights come on...It has happened a couple times...
  9. #9
    Join Date
    May 2007
    California
    Posts
    12,056
    Ride
    Other
    Thanks Given
    304
    Thanks Received:
    365
    What size are your tires and how are your brake pads? Do you have a code reader?
  10. #10
    Join Date
    Oct 2008
    MN
    Posts
    82
    Thanks Given
    Thanks Received:
    Stock 18's, brake were done about 6 months ago I was told, just picked this up a few weeks ago.
    No code reader here, could run to autozone and have them pull the code it self.
  11. #11
    Join Date
    May 2007
    California
    Posts
    12,056
    Ride
    Other
    Thanks Given
    304
    Thanks Received:
    365
    Quote Originally Posted by 05FX35 View Post
    Codes would help.
    Also, how is your brake fluid and alignment?
  12. #12
    Join Date
    Oct 2008
    MN
    Posts
    82
    Thanks Given
    Thanks Received:
    I will try to get the codes tonight.
    Didn't check today, but when I got back from mexico checked everything over and the brake fluid is good. Alignment is dead on from what I can tell.
  13. #13
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    was thinking brake fluid level but that always is accompanied by the red brake light...
    if it was a one time thing woulda said maybe one wheel slipped on a banana peel or something, but recurring guess not.. & it still wouldn't stay on anyway...
  14. #14
    Join Date
    Jun 2007
    Bay Area
    Posts
    1,429
    Darryl
    Ride
    2003 FX35 AWD
    Thanks Given
    4
    Thanks Received:
    13
    I was told the same thing, that its fluids that cause the light to come on. who knows for sure, cause I've checked the fluid levels they were fine and the light came on and went off. The dealer said don't worry unless the light stays on. haven't seen it since, now it time to check my belts lil noisy in the a.m....
  15. #15
    Join Date
    Jul 2008
    sherman oaks, ca
    Posts
    851
    Ride
    2005 FX35 RWD
    Thanks Given
    11
    Thanks Received:
    6
    Thanks
    How about your steering wheel? when you drive it straight does it look straight? It may not pull to one side which would indicate that your Alignment is good, but does the stearing wheel look straigt?
    Quote Originally Posted by Deecarp View Post
    Anything that has to do with Break fluid, pads, and rotors, will have a Red Break light along with the VDC and Slip.
  16. #16
    Join Date
    Jun 2007
    Santa Clarita, CA
    Posts
    10,331
    Ride
    2005 FX45
    Thanks Given
    6
    Thanks Received:
    18
    Happened to me when my pads were low and needed replacing.
  17. #17
    Join Date
    Mar 2008
    Southern California
    Posts
    5,928
    Ride
    2005 FX35 RWD
    Thanks Given
    50
    Thanks Received:
    11
    ... could run to autozone and have them pull the code it self.
    FYi
    fact: in California, they stopped loaning the OBDII scanner at AutoZone. Pepboys wants $20 to read it to you. hopefully they haven't stopped at your local store.
  18. #18
    Join Date
    Mar 2008
    Southern California
    Posts
    5,928
    Ride
    2005 FX35 RWD
    Thanks Given
    50
    Thanks Received:
    11
    ok my VDC and Slip light came on today (1st time )
    FACT: I am due for an oil change and the on board computer was telling to to PIT - oil change- (I set the interval myself)
    I ignored the reminder since I had to goto vegas over the weekend. (so maybe ~600 miles over the setpoint)
    when I first saw the light I drove around until I could park. restarted engine and cleared the GPS stuff and lights were still off. turned off engine.
    then I restarted the engine , this time I didn't clear the GPS stuff and the lights came on as soon as I stepped on the brakes.
    I was able to keep the lights off until I changed the oil.
    but before I did the oil change, I reset the oil change reminder for another 5500 miles.
    Light did not come back.
    changed oil and light has not come back.
    do you guys think it is related to the message from the on board computer ?(ie oil change reminder)
    hope this helps in finding an answer to the mystery.
  19. #19
    Join Date
    Jun 2007
    Santa Clarita, CA
    Posts
    10,331
    Ride
    2005 FX45
    Thanks Given
    6
    Thanks Received:
    18
    No I doubt it as the oil change light came on for many a times and never with a VDC and/or slip light. It was probably a coincidence. When the oil change maintenance reminder comes on I just turn it off until I can get the oil changed then I reset it. But do you think you need brake service or your brake fluids are low?
  20. #20
    Join Date
    Mar 2008
    Southern California
    Posts
    5,928
    Ride
    2005 FX35 RWD
    Thanks Given
    50
    Thanks Received:
    11
    I'll check the brake fluid . thanks
Similar Threads
  1. [FX45 03-08] Lights on Dash: AWD, SLIP, NO VDC, ABS
    By Chedman13 in forum FX (03-08) - Wheels & Suspension
    Last Post: 11-10-2014, 09:23 PM
  2. [FX35 03-08] Have no brake lights after slip/dtc lights on.
    By Blackrhino in forum FX (03-08) - Electronics & Lighting
    Last Post: 09-15-2010, 08:27 AM
  3. Brake, Slip and VDC OFF Lights
    By Dr.2K in forum FX (03-08) - Wheels & Suspension
    Last Post: 11-01-2009, 06:55 AM
  4. SLIP & VDC off lights
    By jumbosrule in forum FX (03-08) - Wheels & Suspension
    Last Post: 05-20-2009, 04:19 PM
  5. VDC and SLIP lights come on at 45mph
    By FXtion in forum FX Community
    Last Post: 11-13-2008, 03:33 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
