What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 7 of 7
  1. #1
    Join Date
    May 2011
    New York
    Posts
    5,027
    Ride
    2009 FX35 AWD
    Thanks Given
    234
    Thanks Received:
    175
    Help milky white substance in my motor oil!!!
    Today I decides to check the oil level and when I pull out the dipstick I notice a milky white substance in the motor oil sample on the dipstick. First I try to stay calm but then I decide to check the fill cap and its there too!!! Wth is this antifreeze in my motor oil??? I only have 52K miles on this car.
    Someone said it could be condensation from not driving it and just starting it up once a while. I have to move it out of the driveway 5 times a week to get out of the driveway then I put it back and just park it.
    Pictures attached!!
    Sent from my SPH-L720 using Tapatalk
    See More: Help milky white substance in my motor oil!!!
    Register
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	10181   Click image for larger version.
ID:	10182   Click image for larger version.
  2. #2
    Join Date
    May 2011
    New York
    Posts
    5,027
    Ride
    2009 FX35 AWD
    Thanks Given
    234
    Thanks Received:
    175
    Also I like to add that I haven't been loosing any coolant the level is exactly the same all the time
  3. #3
    Join Date
    Apr 2008
    Kincardine, Ontario, Ca
    Posts
    11,026
    Wayne
    Ride
    2010 FX50S
    Thanks Given
    443
    Thanks Received:
    649
    I say it is condensation Aaron. It is always bad for a car to start it up like that, it never gets a chance to warm up and get rid of that moisture. It is hard on your engine and exhaust system.
    Whenever I start my vehicles they are always fully warmed up, meaning the thermostat has opened and usually I have had the car up to highway speeds (but, where I live that is easy to do)
    Is it not possible to park it so it doesn't have to be moved around so much. You should the change oil much more frequently also with short drives, by the sounds of it your FX probably isn't hardly off the fast idle and you shut it off.
  4. #4
    Join Date
    Jun 2009
    Hollywood, CA
    Posts
    3,485
    Andy
    Ride
    2004 FX35 RWD
    Thanks Given
    66
    Thanks Received:
    140
    I would change the oil
  5. #5
    Join Date
    May 2011
    New York
    Posts
    5,027
    Ride
    2009 FX35 AWD
    Thanks Given
    234
    Thanks Received:
    175
    Thanks guys for the reply. Yeah I don't let it heat up and I just move it right away. I just changed the motor oil like 3 weeks ago. The way my driveway is set up is that if I need to get out I have to move cars behind me. Its very annoying too :(
    If its condensation do you think the car is alright? I'd hate to change the motor oil again after just changing it a few weeks ago and it only has like 100 miles on this oil.
  6. #6
    Join Date
    Apr 2008
    Posts
    11,026
    Wayne
    Ride
    2010 FX50S
    Thanks Given
    443
    Thanks Received:
    649
    Quote Originally Posted by Fire0nic3FX View Post
    Take it for a good run Aaron, then you will burn all that condensation out of it along with the unburnt gases that has probably mixed with your oil since it has only been run with the choke on.
    It will be fine, I would definitely try and change your moving cars around system because it will eventually start to affect your car.
  7. #7
    Join Date
    Oct 2013
    New York
    Posts
    31
    Ride
    2013 FX50S
    Thanks Given
    14
    Thanks Received:
    I agree w condensation. I would also remove the radiator cap and look closely at the antifreeze on the top - if you see oil- and it will be more than obvious - then be concerned. My old LT1 motor was notorious for this type of condensation - and was fine
Similar Threads
  1. [FX35 03-08] Antifreeze & Motor Oil
    By Jdiamond in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 11-10-2013, 05:23 PM
  2. 04 350Z motor vs 05 FX35 motor
    By LeBron23 in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 02-25-2012, 02:05 AM
  3. Knocking In the Motor
    By B-NUTS in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 06-24-2010, 05:25 PM
  4. [FX35 03-08] window motor ?
    By kakes in forum FX (03-08) - Interior & Exterior
    Last Post: 12-16-2009, 07:16 PM
  5. [FX45 03-08] Mixing Motor Oil
    By black_stallion in forum FX (03-08) - FX45 Engine & Drivetrain
    Last Post: 02-23-2009, 06:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
