What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 19 of 19
  1. #1
    Join Date
    Sep 2012
    North Carolina
    Posts
    33
    Ride
    2005 FX45
    Thanks Given
    15
    Thanks Received:
    all wheel drive full time?
    Do the fx45 all wheel drive shut off at a certain speed or are they full time all wheel drive?
    Register
  2. #2
    Join Date
    May 2011
    Toronto, Canada
    Posts
    2,728
    Ride
    2008 FX35 AWD
    Thanks Given
    85
    Thanks Received:
    72
    From my understanding its rwd based and when the rears slip the front kicks in.
  3. #3
    Join Date
    Jun 2009
    Hollywood, CA
    Posts
    3,500
    Andy
    Ride
    2004 FX35 RWD
    Thanks Given
    66
    Thanks Received:
    142
    ^ what he said
  4. #4
    Join Date
    May 2010
    Sugar Hill GA
    Posts
    242
    Ride
    2011 FX35 RWD
    Thanks Given
    11
    Thanks Received:
    2
    With my 2009 FX50S I heard that it always starts out (from a dead stop) in 4WD and then will switch to only RWD at speeds above 12 MPH? I have never been able to spin the rear tires from a dead stop? Maybe its the VDC preventing rear wheel slip?
  5. #5
    Join Date
    May 2012
    san diego
    Posts
    206
    Ride
    2005 FX35 AWD
    Thanks Given
    Thanks Received:
    7
    ^^^ what she said.. j/k..
    rear wheel biased unlike lexus which is front..
  6. #6
    Join Date
    Jul 2007
    NYC
    Posts
    6,307
    Ride
    2008 FX45
    Thanks Given
    27
    Thanks Received:
    246
    Correct for both gens. AWD FX's start in AWD mode when moving from a stop. It will then default to RWD until AWD is needed again.
  7. #7
    Join Date
    May 2011
    Toronto, Canada
    Posts
    2,728
    Ride
    2008 FX35 AWD
    Thanks Given
    85
    Thanks Received:
    72
    so i was mistakened?
  8. #8
    Join Date
    Apr 2008
    Big Bear City,Ca.
    Posts
    4,399
    John Green
    Ride
    2004 FX35 AWD
    Thanks Given
    103
    Thanks Received:
    108
    Snow button...does two things:
    1. Reduces throttle sensitivity. This means that if you slam on the gas pedal, it will purposely open the throttle (butterfly valve in the throttle body) much slower than if you were not in snow mode, resulting in a more controlled acceleration from stop.
    2. Raises the AWD-RWD transfer speed. Like many others here, I don't know the EXACT speed at which the ECU tells the TCU to make a RWD powertrain. Again, from what I remember, this number is 19mph. In snow mode, you will maintain the AWD start for higher speeds than if the button was not depressed. The transmission will still be RWD biased and will revert to a RWD, just a little later on.
    The '03 models did not have a snow button, but rather an AWD Lock button, which did the same thing except did not have the throttle sensitivity adjust that the snow mode has.
    ATTESA E-TS traction system
    Infiniti's advanced Vehicle Dynamic Control (VDC) system with Traction Control System (TCS) is standard on all FX models. VDC adjusts brake pressure and engine torque automatically in understeer, oversteer or slippery road surface situations, helping the driver keep the intended path.
    The ATTESA E-TS™ (Advanced Total Traction Engineering System for All Electronic Torque Split) all-wheel drive system utilized on FX45 and FX35 AWD uses an advanced torque split control strategy that automatically transfers optimum torque to the wheels according to road and driving conditions. The system provides outstanding handling due to optimum torque distribution for front and rear SNOW MODE(50:50 up to 0:100). ATTESA E-TS™ also provides high starting traction performance and smooth, stable acceleration, especially in snow-covered or off-road situations with a 50:50 torque split at standing start.
  9. #9
    Join Date
    Nov 2011
    Milwaukee
    Posts
    2,858
    Justin
    Ride
    2007 FX35 AWD
    Thanks Given
    38
    Thanks Received:
    159
    ^ what he said.
  10. #10
    Join Date
    Dec 2012
    Northern Va
    Posts
    10
    Ride
    2005 FX35 AWD
    Thanks Given
    Thanks Received:
    Nice, good info...now that it will snow tomorrow, I will play around!!! (Hopefully)
  11. #11
    Join Date
    May 2011
    Oregon
    Posts
    701
    Ride
    2010 FX35 AWD
    Thanks Given
    14
    Thanks Received:
    3
    So this goes for the 2010 2nd gens AWDs? Starts in AWD to remain that traction then goes into RWD. What if we turn off the VDC does it still start in AWD or does turning the VDC off keep the car in RWD. I remember someone modding their AWD FX into a RWD and was able to burnout but someone said it could ruin the transmission.
  12. #12
    Join Date
    May 2011
    Toronto, Canada
    Posts
    2,728
    Ride
    2008 FX35 AWD
    Thanks Given
    85
    Thanks Received:
    72
    Quote Originally Posted by 2010fx35 View Post
    i think its the same with the 2nd gens also. If im not mistakened, theres a member here with a supercharged awd fx and drives around with the fuse off all the time
  13. #13
    Join Date
    Dec 2011
    Wolcott, Ct.
    Posts
    2,434
    Joey
    Ride
    2003 FX35 AWD
    Thanks Given
    60
    Thanks Received:
    72
    Yeah this is what I have in my '03 FX I use it when it snows but dont always leave it on because I dont know if Im supposed to or if it will cause damage if its on all the time. So I use it to get out of sticky situations.
  14. #14
    Join Date
    May 2011
    Oregon
    Posts
    701
    Ride
    2010 FX35 AWD
    Thanks Given
    14
    Thanks Received:
    3
    Quote Originally Posted by Viperi View Post
    Yeah i remember seeing it way long ago and read that it could ruin something. Not sure how but it goes with like towing a awd car. Its better to put it on a bed insted of just towing it on its rear wheels.
  15. #15
    Join Date
    Oct 2009
    Portland, OR
    Posts
    10,212
    Ride
    2004 FX35 AWD
    Thanks Given
    97
    Thanks Received:
    191
    Pulling the fuse doesn't even trigger a CEL. It wont hurt anything. The front diff is electronically actuated, so if the fuse burns out it won't kill your transmission, it will just be full time rwd.
  16. #16
    Join Date
    May 2011
    Oregon
    Posts
    701
    Ride
    2010 FX35 AWD
    Thanks Given
    14
    Thanks Received:
    3
    Its been raining pretty hard thought it be fun to burn out alittlle :). I found the thread though, sadly it died off right when a fx50 looked through the fuse boxes and only found two VDC fuses. No AWD SOL.
  17. #17
    Join Date
    Jan 2013
    Ohio
    Posts
    13
    Ride
    Other
    Thanks Given
    Thanks Received:
    This is good info since I'm looking for an AWD.
  18. #18
    Join Date
    Jan 2012
    Lyndhurst, NJ
    Posts
    960
    Ride
    2004 FX35 AWD
    Thanks Given
    27
    Thanks Received:
    33
    i think it runs awd till 15 or 25 mph and then it just flows rwd until it detects slip
  19. #19
    Join Date
    Aug 2011
    alpharetta,ga
    Posts
    270
    Ride
    2004 FX45
    Thanks Given
    19
    Thanks Received:
    13
    +1 to mostly RWD and then AWD when the system notices that a wheel or wheels are slipping.
Similar Threads
  1. [FX50S 09+] Intelligent All-Wheel Drive
    By PRICE31 in forum FX (09+) - Wheels & Suspension
    Last Post: 01-04-2013, 07:44 PM
  2. 2013 Infiniti JX35 Drive Time Review
    By Fire0nic3FX in forum Infiniti JX QX60 Forum
    Last Post: 07-23-2012, 12:52 PM
  3. [FX45 03-08] How many miles can you drive if you full it up?
    By dwell6 in forum FX (03-08) - FX45 Engine & Drivetrain
    Last Post: 11-09-2009, 02:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
