What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 20 of 20
Thread: Timing chain
  1. #1
    Join Date
    May 2009
    Brooklyn
    Posts
    639
    Ride
    2004 FX35 AWD
    Thanks Given
    5
    Thanks Received:
    2
    MAINT Timing chain
    What's up guys. I got a quick question. Did anyone ever replace their timing chain and guides. I know they really don't have to get replaced but did anyone every have one go bad on them.
    See More: Timing chain
    Register
  2. #2
    Join Date
    Oct 2009
    Portland, OR
    Posts
    10,212
    Ride
    2004 FX35 AWD
    Thanks Given
    97
    Thanks Received:
    191
    People usually replace them during rebuilds, but I've never heard of a chain failing.
    SfmDRuT2
  3. #3
    Join Date
    Sep 2011
    Chicago
    Posts
    675
    Ride
    Other
    Thanks Given
    6
    Thanks Received:
    20
    The plastic guides normally fail first. Causing a horrible rattle noise. And once your in there you might as well do everything.
  4. #4
    Join Date
    Apr 2010
    Inland Empire, CA
    Posts
    3,730
    Ride
    2003 FX45
    Thanks Given
    55
    Thanks Received:
    151
    What makes this timing chain system different compared to other engines that require changing at specific intervals?
  5. #5
    Join Date
    May 2009
    Brooklyn
    Posts
    639
    Ride
    2004 FX35 AWD
    Thanks Given
    5
    Thanks Received:
    2
    I'm taking a guess to as if that's what's causing the whining noise on my car.
  6. #6
    Join Date
    Jun 2009
    Hollywood, CA
    Posts
    3,485
    Andy
    Ride
    2004 FX35 RWD
    Thanks Given
    66
    Thanks Received:
    140
    A time chain is definitely better. Not only will it last longer, but if a chain breaks it breaks and that's all that happens; you have to repair it. When a belt breaks you run the risk of causing damage to the surrounding areas of your car.
  7. #7
    Join Date
    Sep 2011
    Chicago
    Posts
    675
    Ride
    Other
    Thanks Given
    6
    Thanks Received:
    20
    Quote Originally Posted by Dracula View Post
    If ur talking about interference and non interference motors then you are incorrect. Pending on design of motor, when a belt/ chain breaks it could destroy the engine, IE piston hits valve. That is a interference motor. It could be chain or belt driven.
    Originally a belt driven motor was quieter compared to a chain. Chains often last 500k or life of car compared to belts that need replacement at 60-105k. Some timing belts are quick and easy to do I rather prefer belts ( most sohc 4 cylinder) and some I hate with a passion (vw/Audi v6 motors). There is no better, its a trade off. Kinda like going v6 vs v8.
  8. #8
    Join Date
    Sep 2011
    Chicago
    Posts
    675
    Ride
    Other
    Thanks Given
    6
    Thanks Received:
    20
    Quote Originally Posted by Mikefx35 View Post
    YouTube some timing chain guide rattles. Motors like a ka24de, sr20de or the motor in the first gen q45. See if those noise match up with yours. Its a plastic and metal guide, it could be worn down rather.
  9. #9
    Join Date
    May 2009
    Brooklyn
    Posts
    639
    Ride
    2004 FX35 AWD
    Thanks Given
    5
    Thanks Received:
    2
    Nothing close to those noises. I can't figure what's causing the noise the car runs perfectly but that noise is bothering me
  10. #10
    Join Date
    Sep 2011
    Chicago
    Posts
    675
    Ride
    Other
    Thanks Given
    6
    Thanks Received:
    20
    It is at start up only or always there?
    Check your pulleys. Either idler pulleys( I don't think fx35 motors have them) and all the others. They go out from time to time. I had a bad idler pulley in my g35 at 50k. I just deleted it.
  11. #11
    Join Date
    Jun 2011
    Miami
    Posts
    6,662
    Ride
    2004 FX35 AWD
    Thanks Given
    176
    Thanks Received:
    448
    ^ he just replaced the pulleys and noise is still there
    •TapaTalk•
  12. #12
    Join Date
    Aug 2011
    brooklyn
    Posts
    389
    Ride
    2004 FX35 AWD
    Thanks Given
    36
    Thanks Received:
    5
    I had a whining noise on my old Chevy impala 2001 and It was the tranny. Remove the belt from the engine and start the car if you still have the whining then its coming from the tranny
  13. #13
    Join Date
    May 2009
    Brooklyn
    Posts
    639
    Ride
    2004 FX35 AWD
    Thanks Given
    5
    Thanks Received:
    2
    I removed the belts n cranked the car it's still making the noise. I doubt it's my tranny or engine. The car runs fine all fluid are clean and up to there level
  14. #14
    Join Date
    Aug 2011
    brooklyn
    Posts
    389
    Ride
    2004 FX35 AWD
    Thanks Given
    36
    Thanks Received:
    5
    If you remove the belt and still getting the whining and most likely it should be the tranny because remember by removing the belt you just eliminated everything that sits on the engine
  15. #15
    Join Date
    May 2009
    Brooklyn
    Posts
    639
    Ride
    2004 FX35 AWD
    Thanks Given
    5
    Thanks Received:
    2
    But everything is working fine. Tranny shifts fine and smooth though the noise is a come and go type of thing. It doesn't do it when it starts up about 15 min after the engine got warmed up. It happens mostly at idle it could be happening when driving but I can't hear it. It'll come on and then it'll go away
  16. #16
    Join Date
    Sep 2011
    ny
    Posts
    1,036
    Ride
    2005 FX45
    Thanks Given
    22
    Thanks Received:
    22
    Just a thought could it be a bent valve or something ? I thin i seen a similar case with a bent valve ....... I dont mean to have u worry mike hope all is well man .....
  17. #17
    Join Date
    Jun 2007
    Santa Clarita, CA
    Posts
    10,331
    Ride
    2005 FX45
    Thanks Given
    6
    Thanks Received:
    18
    I would check your oil level. I bet its low and the whining noise can come from low levels. Probably needs a quart or two.
  18. #18
    Join Date
    May 2009
    Brooklyn
    Posts
    639
    Ride
    2004 FX35 AWD
    Thanks Given
    5
    Thanks Received:
    2
    All my oil levels are good engine and tranny wise.
  19. #19
    Join Date
    Apr 2010
    Inland Empire, CA
    Posts
    3,730
    Ride
    2003 FX45
    Thanks Given
    55
    Thanks Received:
    151
    Can you take a video or sound clip?
  20. #20
    Join Date
    May 2009
    Brooklyn
    Posts
    639
    Ride
    2004 FX35 AWD
    Thanks Given
    5
    Thanks Received:
    2
    I posted a video link on my other thread called whinning noise.
Similar Threads
  1. [FX35 03-08] CAI Timing Problems
    By FXMonster in forum FX (03-08) - Boost, Track & Tuning
    Last Post: 08-25-2011, 11:31 AM
  2. [FX35 09-12] FX35 09+ Snow chain recommed on 20" OEM wheel?
    By jsseattle in forum FX (09+) - Wheels & Suspension
    Last Post: 12-02-2010, 02:19 PM
  3. [PRODUCT REVIEW] Leather Key Chain
    By k3fir in forum Deals & Reviews
    Last Post: 11-21-2010, 07:51 AM
  4. [FX45 03-08] +2 Timing
    By "LittleGagne" in forum FX (03-08) - FX45 Engine & Drivetrain
    Last Post: 11-12-2010, 08:58 PM
  5. 713 +2 timing meet
    By jumbosrule in forum Midwest South
    Last Post: 01-27-2010, 10:15 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
