What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 13 of 13
  1. #1
    Join Date
    Feb 2008
    South Bay 310
    Posts
    631
    Ride
    2003 FX35 RWD
    Thanks Given
    3
    Thanks Received:
    MAINT Serpentine Belts
    Damn it, only around 43K miles on 03' FX35, and the thinner belt already has cracks......the bigger one still perfect! What the f.....any of you have this problem?
    Is it easy to replace the belts?
    Register
  2. #2
    Join Date
    Jun 2007
    Westminster OC
    Posts
    2,550
    Ride
    2005 FX35 RWD
    Thanks Given
    3
    Thanks Received:
    5
    Should not be hard at all to replace yourself. I see you're in Torrance, if you get the belts yourself from a dealer Technosquare can swap them out pretty quickly. My smaller belt had cracks in it before the larger belt did.
  3. #3
    Join Date
    Feb 2008
    South Bay 310
    Posts
    631
    Ride
    2003 FX35 RWD
    Thanks Given
    3
    Thanks Received:
    Cracks
    When did you change your belts? 43k miles sounds a little low for the belts to be cracking already right.
  4. #4
    Join Date
    Jun 2007
    California
    Posts
    12,191
    Ride
    Other
    Thanks Given
    313
    Thanks Received:
    422
    I still have the stock smaller belt on my car with over 40,000 miles.
    Changing them is pretty easy but to change the smaller belt you have to take off the bigger belt.
  5. #5
    Join Date
    Feb 2008
    South Bay 310
    Posts
    631
    Ride
    2003 FX35 RWD
    Thanks Given
    3
    Thanks Received:
    hmm
    Have you inspected your smaller belt yet? Mine has a lot of cracks, just a little worried. How many more miles do you have when it's showing a lot of cracks?
  6. #6
    Join Date
    Oct 2007
    Seattle
    Posts
    1,434
    Ride
    2003 FX45
    Thanks Given
    Thanks Received:
    4
    does the 45's have the same amount of belts as well 1 big and 1 smaller one. I can't find 2 on the infinitipartsusa. just the 1 bigger one.
  7. #7
    Join Date
    Jul 2007
    Vancouver, BC
    Posts
    566
    Ride
    2005 FX35 AWD
    Thanks Given
    Thanks Received:
    11
    The FX45 uses two belts.
  8. #8
    Join Date
    Nov 2008
    Rhode Island
    Posts
    23
    Ride
    2006 FX35 AWD
    Thanks Given
    Thanks Received:
    2
    Quote Originally Posted by puhahacj View Post
    Took me 30 min to replace both belts. There are tensioners on each belt that allow you to loosen and slack the belt for removal and replacemnt.
    I went with the Goodyear Gatorback belts from autozone. About $50 for both. These have softer feel to them and have sectioned grooves that make them extremely quiet.
    Tip while you are at it: remove the whole tensioner pulleys and clean/re-grease them to keep them quiet for the next 60K miles.
  9. #9
    Join Date
    Apr 2009
    los angeles
    Posts
    5
    Thanks Given
    Thanks Received:
    Quote Originally Posted by 06FX35 View Post
    hi, if you could shed more light on how you replaced the belts...
    did you use some tool to measure tension after you were done?
    if not, how did you know how much to tighten?
    thanks in advance!
  10. #10
    Join Date
    Feb 2008
    South Bay 310
    Posts
    631
    Ride
    2003 FX35 RWD
    Thanks Given
    3
    Thanks Received:
    Quote Originally Posted by 310fx View Post
    thanks in advance!
    Here is a good thread for the instructions:
    http://www.infinitiscene.com/forum/s...ead.php?t=1869
    Also, the tensioner is automatic, so no need to measure
  11. #11
    Join Date
    Apr 2009
    los angeles
    Posts
    5
    Thanks Given
    Thanks Received:
    Thanks...
    I still have a question on how much to tighten the four bolts.
    Is there a torque range for bolts a and c?
    Do you tighten bolts b and d until the belts "look" tight and let the auto tension mechanism handle the rest?
  12. #12
    Join Date
    Mar 2008
    chicago
    Posts
    546
    Ride
    2005 FX45
    Thanks Given
    Thanks Received:
    i went to autozone yesterday and the guy there argued with me that i only have one belt. i just walked out.
  13. #13
    Join Date
    Nov 2008
    NYC
    Posts
    3,025
    Ride
    2005 FX35 AWD
    Thanks Given
    2
    Thanks Received:
    8
    Quote Originally Posted by chiFX45 View Post
    Good one! I would have done the same. He probably thought you was a regular car owner that didn't know anything about your vehicle. I hate when that happeneds.
Similar Threads
  1. [FX35 03-08] DIY Belts/Pulley
    By Tko512iFX in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 12-28-2011, 12:20 PM
  2. [FX35 03-08] Cracking belts
    By DodgeDanger in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 08-11-2009, 05:35 PM
  3. [FX35 03-08] Belts or pulleys
    By PhilDRich in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 06-03-2009, 01:00 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
