What's New Home Forum Top
Supporter Rides
Register
Page 1 of 2 12 LastLast
Results 1 to 20 of 30
  1. #1
    Join Date
    Jan 2012
    Rochester Ny
    Posts
    9
    Ride
    2003 FX35 AWD
    Reviews
    Thanks Given
    Thanks Received:
    Wheels / Suspension 22 Range rover 22x10 wheels to Fit or not To fit?
    Please tell me these will fit. I'm a new guy on the forum and i have been doing research on a nice set of 22's that wont take away from the factory look and I have concluded that search with these wheels. Please tell me these will fit i love them!!! The specs are 22x10" Wheel Offset is 50mm. Hub size is 72.56mm Bolt Pattern is 5x120mm. will these fit with a 20mm 5x114.3 to 5x120 adapter i was thinking about getting 20mm for front and 25mm for rear. I have a awd 2003 fx35
    Register
  2. # ADS
    Advertisement Google Ad
    Join Date
    Always
    Here
    Posts
    Some
    Supporters do not see these ads. Click Here
  3. #2
    Join Date
    Jul 2007
    Illinois
    RiSC
    MWFX
    Posts
    4,331
    Ride
    2003 FX45
    Reviews
    Thanks Given
    64
    Thanks Received:
    81
    Quote Originally Posted by onmyway View Post
    Yes, they will fit. Get 25mm adapters all around, as they will 100% clear the OEM studs.
    I run 24x10 +45 on 25mm adapters from 72.56mm to 66.1mm or whatever our hub bore is.
    Call Motorsport tech and ask for junior. Don't order via online as you need to discuss stud length cut to OEM range rover length (mine were too long, he knows that). Note studs are different size too and OEM lug nuts are around a couple hundred dollars, if they are the flat mag style and not cone seat.
  4. #3
    Join Date
    May 2010
    Hawaii
    Posts
    70
    Ride
    2006 FX35 RWD
    Reviews
    Thanks Given
    Thanks Received:
    I got Motorsport tech adapters as well and those things are really great quality
  5. #4
    Join Date
    Jul 2007
    Illinois
    RiSC
    MWFX
    Posts
    4,331
    Ride
    2003 FX45
    Reviews
    Thanks Given
    64
    Thanks Received:
    81
    Quote Originally Posted by inky View Post
    Nice, what are your specs, just curious.
  6. #5
    Join Date
    May 2010
    Hawaii
    Posts
    70
    Ride
    2006 FX35 RWD
    Reviews
    Thanks Given
    Thanks Received:
    I ended up using the rims from my old BMW. 22X10.5 +40 in the rear and 22X9 +35 front. The adapters are 5X120bp and 73.1 bore for the rims to our 5X114.3bp 66.1cb and the thickness is 19mm which is the thinnest they make. I used the same studs size too, 12X 1.25. I didn't need to modify the rims at all with the short adapters as my rims already had pockets on the mounting surface so that little bit of the stock stud that poked out past the adapter fit perfectly in the recess of the rim mounting pad. It's a tight fit with the coilovers and 305s but it fits perfect and does not rub at all.
  7. #6
    Join Date
    Jan 2012
    South Florida
    Posts
    44
    Ride
    2007 FX35 RWD
    Reviews
    Thanks Given
    Thanks Received:
    ^Would love to see some photos
  8. #7
    Join Date
    Jan 2012
    Rochester Ny
    Posts
    9
    Ride
    2003 FX35 AWD
    Reviews
    Thanks Given
    Thanks Received:
    Thanks guys For the help! After the 6 months of looking ive decided to go with a set on 22x10 inch Rinspeed off of a range rover. Got 5 Brand new rims and tires for 1100 shipped couldnt pass it.
  9. #8
    Join Date
    Mar 2009
    Katy, TX
    RiSC
    TXFX
    Posts
    1,280
    Ride
    2006 FX35 RWD
    Reviews
    Thanks Given
    3
    Thanks Received:
    2
    Wow thats a hell of a deal! Pics!
  10. #9
    Join Date
    Apr 2010
    Inland Empire, CA
    RiSC
    SCiS
    Posts
    1,139
    Ride
    2003 FX45
    Reviews
    Thanks Given
    10
    Thanks Received:
    16
    .. must ... have ... pics
  11. #10
    Join Date
    Jul 2007
    Infiniti of Massapequa
    RiSC
    NEFX
    Posts
    439
    Ride
    2011 M37S
    Reviews
    Thanks Given
    3
    Thanks Received:
    5
    my friend has adapters on his scion tc to fit the 335i rims on, which look great -- he says no vibrations from them. definitely post pics of the RR wheels!
  12. #11
    Join Date
    Jan 2012
    Rochester Ny
    Posts
    9
    Ride
    2003 FX35 AWD
    Reviews
    Thanks Given
    Thanks Received:
    Thank you....Im waiting on them now!! There going straight from the ups truck to my trunk then to the wheel shop....I will keep you guys posted
  13. #12
    Join Date
    Jan 2012
    Rochester Ny
    Posts
    9
    Ride
    2003 FX35 AWD
    Reviews
    Thanks Given
    Thanks Received:
    Ok They are on the vehicle i just need to post some more so i can put up pics....... they look phenomenal
  14. #13
    Join Date
    Apr 2008
    Kincardine, Ontario, Ca
    RiSC
    GTAFX
    Posts
    3,073
    Ride
    2009 FX35 AWD
    Reviews
    Thanks Given
    10
    Thanks Received:
    38
    Subscribing for pics
  15. #14
    Join Date
    Apr 2009
    Ontario
    RiSC
    GTAFX
    Posts
    1,078
    Ride
    2004 FX35 AWD
    Reviews
    Thanks Given
    3
    Thanks Received:
    15
  16. #15
    Join Date
    Mar 2011
    Illinois
    RiSC
    MWFX
    Posts
    883
    Ride
    2003 FX45
    Reviews
    Thanks Given
    17
    Thanks Received:
    8
    I can't wait so see them, PICS!
  17. #16
    Join Date
    Oct 2010
    Ann Arbor, MI / Canton, MI / Chicago, IL
    RiSC
    MWFX
    Posts
    4,383
    Ride
    2009 FX50S
    Reviews
    Thanks Given
    22
    Thanks Received:
    66
    Quote Originally Posted by J3FF3R$0N View Post
    love it!
  18. #17
    Join Date
    Jun 2011
    Dairy Capital
    RiSC
    MWFX
    Posts
    910
    Ride
    2004 FX35 AWD
    Reviews
    Thanks Given
    16
    Thanks Received:
    32
    ^+1.
  19. #18
    Join Date
    Oct 2010
    RiSC
    MWFX
    Posts
    4,383
    Ride
    2009 FX50S
    Reviews
    Thanks Given
    22
    Thanks Received:
    66
    What's funny is when I read the quote of the pic, I read it exactly like from the movie lol.
  20. #19
    Join Date
    Jan 2012
    Rochester Ny
    Posts
    9
    Ride
    2003 FX35 AWD
    Reviews
    Thanks Given
    Thanks Received:
    flickr.com/photos/77620163@N02/6809994642/in/photostream/
    ---------- Post added at 08:07 AM ---------- Previous post was at 08:02 AM ----------
    Just took a couple off pics. Hope you guys like them. No lowering or anything of that sort its the family vehicle so im trying to keep it simple other then the rims and flowmaster exhaust smh
    flickr.com/photos/77620163@N02/6956105251/in/photostream/
  21. #20
    Join Date
    Jun 2007
    California
    Posts
    8,884
    Ride
    2008 M45
    Reviews
    5
    Thanks Given
    29
    Thanks Received:
    72
Similar Threads
  1. [FX GEN2] Lexani CVX-55: 22x10.5, Will it fit??
    By bobby2478 in forum FX ('09+) Wheels & Suspension
    Last Post: 04-30-2012, 09:13 AM
  2. Land Rover LRX concept
    By rookie in forum Automotive Other
    Last Post: 10-17-2011, 11:35 AM
  3. Joined The Dark Side - 2008 Range Rover Sport HSE
    By M3-ADDICT in forum Automotive Other
    Last Post: 08-24-2010, 07:56 PM
  4. [FX35 03-08] 22x10 40mm
    By twistedtahoe in forum FX ('03-'08) Wheels & Suspension
    Last Post: 05-11-2010, 09:34 AM
  5. [FX35 03-08] GPS Satellite Out of Range Help
    By dingie888 in forum FX ('03-'08) Electronics & Lighting
    Last Post: 04-05-2010, 09:47 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
