What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 7 of 7
  1. #1
    Join Date
    Jul 2009
    New Jersey
    Posts
    558
    Ride
    2005 FX35 AWD
    Thanks Given
    Thanks Received:
    6
    MAINT Stillen High Flow Intake Kit Air Filter Change
    Hello all
    I have 05 FX35 and have Stillen High Flow Air Intake Kit installed.
    I was wondering if anyone knows or has DIY/procedure on how to remove the air filter (cone type) as I need to take the filter out. (such as what do I have to remove or take out in order to take the air filter out)
    I will be really appreciated if anyone can describe or provide instruction.
    Thanks in advance!
    See More: Stillen High Flow Intake Kit Air Filter Change
    Register
  2. #2
    Join Date
    Dec 2009
    Chicago
    Posts
    12,143
    Andy
    Ride
    2003 FX45
    Thanks Given
    294
    Thanks Received:
    923
    You simply reverse the installation directions to take the filter out for cleaning. There is no better way that I know.
  3. #3
    Join Date
    Jul 2009
    New Jersey
    Posts
    558
    Ride
    2005 FX35 AWD
    Thanks Given
    Thanks Received:
    6
    The thing is someone else installed the kit for me as I wasn't at the spot when he installed...
  4. #4
    Join Date
    Jul 2009
    New Jersey
    Posts
    558
    Ride
    2005 FX35 AWD
    Thanks Given
    Thanks Received:
    6
    Anyone?
  5. #5
    Join Date
    Jan 2009
    NJ
    Posts
    1,632
    Ride
    Other
    Thanks Given
    9
    Thanks Received:
    16
    Attached are the installation instructions which you are to reverse for removal. Removing the cone filter is very straight forward. Remove the four screws at the back of the heat shield, as well as the screw on the side of the heat shield. After this you will be able to remove the entire heat shield with the cone filter inside it. Slide the filter out of the heat shield and begin the cleaning process. When complete, reinstall the filter and heat shield by following the attached installation instructions.
  6. #6
    Join Date
    Dec 2007
    Westchester, New York
    Posts
    7,003
    Ride
    2009 FX50
    Thanks Given
    3
    Thanks Received:
    95
    it's 4 bolts literally. take the tube off @ the accordian, look at the back of where the cone connets; there are 4 bolts.
  7. #7
    Join Date
    Aug 2008
    Hesperia, CA
    Posts
    2,718
    Ride
    2004 FX35 RWD
    Thanks Given
    21
    Thanks Received:
    92
    Quote Originally Posted by jbaker1121 View Post
    ^yep
    Unscrew the bolt located at the accordian. Then to the right of the box, there should be one more bolt bolted to the fender. This will get the whole "cold air box" out. Then the 4 bolts behind the "cold air box" attaches to your velocity stack (aluminum piece) and the air filter. Once the 4 bolts are out, the filter pops out still attached to the velocity stack. Unscrew the clamp on the filter, and your done.
    be careful and do not overspray the filter...just get it red and wait about an hour to let it soak in before reattaching everything.
Similar Threads
  1. Stillen Hi-flow intake and Ztube Install
    By gashousefx in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 11-10-2012, 05:43 PM
  2. [FX35 03-08] Considering Stillen High Flow Intake
    By drew855 in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 01-03-2011, 08:18 PM
  3. [FX35 03-08] High Flow Cats on the Way!
    By COPPERFX in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 11-26-2010, 11:24 AM
  4. Stillen Intake Filter
    By 909FX in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 08-19-2010, 12:15 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
