What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 11 of 11
  1. #1
    Join Date
    Apr 2009
    Norristown PA
    Posts
    180
    Ride
    2006 FX35 AWD
    Thanks Given
    Thanks Received:
    Electronics tpms not working
    hey guys quick question about tpms. my light came on indicating i had a flat. i quickly pulled over to check my tires to make sure everything was fine. all tires looked good so i check the tpms to fine one sensor not reading pressure. what do you think is going on? :frown:
    See More: tpms not working
    Register
  2. #2
    Join Date
    Oct 2009
    Kazakstan, Aktau
    Posts
    604
    Ride
    2010 FX35 AWD
    Thanks Given
    Thanks Received:
    2
    need to be calibrated,wait a little maybe system will fix it itself.
    or needs dealer programming
    or simply 1 sensor failed
  3. #3
    Join Date
    Jun 2010
    Alberta, Canada
    Posts
    2
    Ride
    2010 FX35 AWD
    Thanks Given
    Thanks Received:
    We are seeing in the industry that the shelf life for the batteries in these sensors is about 4-5 yrs. If you haven`t had a flat repaired recently or the tire pressure is fine. You could have one of the sensors failing due to the battery dieing. Your dealer would be able to turn on that one sensor and re-learn your system if that isn`t the case. If not you may need to replace a sensor.....
  4. #4
    Join Date
    Apr 2009
    Norristown PA
    Posts
    180
    Ride
    2006 FX35 AWD
    Thanks Given
    Thanks Received:
    Well i had my car in at the dealer last thursday. all they did was reset the tpms. They charged me $37, but for the life of me i don't know why the tpms would stop cummunicating while driving unless it was a real flat which it wasn't.
  5. #5
    Join Date
    Sep 2007
    USA
    Posts
    24
    Ride
    2005 FX35 RWD
    Thanks Given
    Thanks Received:
    I got the same problem as the OP. Started 3 days ago. One of them shows two asterix (**) but all tires checked out fine. It does come and go though. I guess the dealer is about to get my $37 too.
  6. #6
    Join Date
    Apr 2009
    Norristown PA
    Posts
    180
    Ride
    2006 FX35 AWD
    Thanks Given
    Thanks Received:
    flat tire light back on
    its been about three weeks i guess, and my tpms is not reading the tire pressure on a different wheel this time. i got in the car to go to work this morning and the flat tire light started flashing. it was fine yesterday when i came from work. my wife drove it last night, and she said it was fine when she parked it last night. i don't know what happen over night as the car sat and then starting it up this morning? it must be someting wrong with maybe the component that reads the pressure, and not so much the monitors in the wheels. :mad.:
  7. #7
    Join Date
    Feb 2010
    Florida
    Posts
    18
    Ride
    2007 FX35 RWD
    Thanks Given
    Thanks Received:
    i have the same problems but it happens when im on the highway...when you paid the $37 did it resolve the issue? cuz my light will go away after i get back on city roads...im deducing that it has something to do when the tires get hot but thats just a shot in the dark...
  8. #8
    Join Date
    Feb 2008
    FONTANA, CA
    Posts
    3,835
    Ride
    2005 FX35 RWD
    Thanks Given
    2
    Thanks Received:
    I have the same problem also. It turns on when I'm on the freeway. If I exit and get a red light, I turn it off and turn it back on and it's gone. Happens maybe once week to once a month. It varies.
  9. #9
    Join Date
    Apr 2009
    Norristown PA
    Posts
    180
    Ride
    2006 FX35 AWD
    Thanks Given
    Thanks Received:
    Electronics tpms
    actually since the last time i posted about the tpms it happen a third time. this time it was the same one as the first time. the dealer finally said it was a bad monitor that i wound up paying $154. its been about two weeks now and that monitor hasn't came back on. i wondering if you can mix and match OE montiors with the one that infinitipartsusa.com were selling for like $45? if that the case then next time i will order from them.
  10. #10
    Join Date
    May 2009
    SE Houston
    Posts
    1,021
    Ride
    2004 FX45
    Thanks Given
    Thanks Received:
    3
    Quote Originally Posted by wiseguywm View Post
    Yes but every new addition will need calibration. Best case wouldbe replace all at once and pay only once for recalibration.
  11. #11
    Join Date
    Sep 2009
    Toronto, Ontario
    Posts
    700
    Ride
    2012 FX35 AWD
    Thanks Given
    8
    Thanks Received:
    37
    Quote Originally Posted by andrew628 View Post
    Actually there's no batteries in these units, they generate power from the spin of the wheel like a generator. That's why it takes a bit for these things to start transmitting their signal. Now if you stop the car the system will retain the PSI reading.
    Just thought I would pass that info since I had one of mine replaced because I broke the stem after trying to take off one of those shiny metal caps (which I found out the hard way that brass doesn't like aluminum stems). The tech told me they don't contain batteries as they would fail quite fast from heat or cold.
Similar Threads
  1. [FX50 09+] TPMS Sensor
    By Guanche01 in forum FX (09+) - Wheels & Suspension
    Last Post: 03-01-2014, 08:53 AM
  2. [FX35 03-08] TPMS Again
    By embdenb in forum FX (03-08) - Wheels & Suspension
    Last Post: 03-24-2011, 03:43 PM
  3. TPMS Light
    By Krayzie in forum FX (03-08) - Wheels & Suspension
    Last Post: 05-01-2009, 12:01 PM
  4. Tpms
    By Darren804 in forum FX (03-08) - Wheels & Suspension
    Last Post: 02-15-2009, 08:13 PM
  5. working hard or hardly working......
    By hotmanali in forum Chat Scene
    Last Post: 08-27-2008, 11:04 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
