[FX35] Stereo/Heater Not working - InfinitiScene.com
InfinitiScene.com
Go Back   InfinitiScene.com > FX Forums > FX Electronics & Lighting
Register Home Page Forums Garage Blogs Members Search Today's Posts Mark Forums Read
[FX Electronics & Lighting] FX Audio, Visual, Electrical, and Lighting.
Reply
Thread Tools
  #1
Old 02-08-2010, 06:55 PM
CrackaJaxson's Avatar
CrackaJaxson CrackaJaxson is offline
Ride: 2008 FX35 AWD
Electronics Stereo/Heater Not working
Hey guys. I was following this thread to replace bose subwoofer with aftermarket amp and subs. Since I only have 3 posts I cant paste the link here Basically its cutting into the sub harness and wiring a line output converter in its place to be able to hook up a new amp.
To make a long story short my stereo and heater no longer turn on. The whole middle console is unresponsive but still lights up. I'm pretty sure I just blew a fuse but dont know where the fuse is located that might be blown. I checked the kick plate fuses on the drivers side and all looked good. Any help??
Register
Sponsored Links
Supporters do not see these ads. Click Here
  #2
Old 02-08-2010, 07:53 PM
Dr.2K's Avatar
Dr.2K Dr.2K is offline
iS Doctor on Duty
RiSC: SCiS
Ride: 2005 FX45
Garage
There are two other fuse box's under the hood in the battery compartment and also behind it.
  #3
Old 02-08-2010, 08:25 PM
tchuck's Avatar
tchuck tchuck is offline
iS Supporter
Ride: 2004 FX35 AWD
Garage
When I was reinstalling my interior after installing sound suppressing material in the trunk area, I inadvertently drove one of the mounting bolts through that sub harness and exactly the same thing happened to me. I had to remove the interior again and repair the harness. After that, everything was fine. I'm guessing you either clipped the wrong wire or the new amp has to be completely installed in order to complete the circuit.
  #4
Old 02-10-2010, 03:49 PM
Ride: 2008 FX35 AWD
Thanks. It was the 15amp fuse in front of the battery. Easy solve.. More troubling issues the farther into the amp install I get. Splicing into the bose sub harness was no big deal. I have the amp wired up correctly with power from the battery, a short ground to the frame and the remote tapped into the bose harness pink wire. Where my issue comes into play is installing an output converter into the mix so my amp gets the correct signal. Im using a stinger slocii converter. It has 2 sets of +/- (1 left, 1 right) and a ground. I hooked the black and white wires from the bose harness into the converter and then the rca's up with no response. I know the white is + and the black is -. When I hook the ground up on the converter my amp goes into protection mode. I dont know why the amp doesnt like the ground or something with the wire config.. when I hook a speaker up to the blk/wht it is producing sound. I dont know where Im going wrong here but i am more than frustrated at this situation... I really dont want to take it to the stereo shop and dish out cash if its an easy fix
  #5
Old 02-10-2010, 07:15 PM
tchuck's Avatar
iS Supporter
Ride: 2004 FX35 AWD
Garage
Which amp do you have?
  #6
Old 02-11-2010, 05:42 AM
Ride: 2008 FX35 AWD
Its an audiobahn A2801q. Its like 5 years old now. Its a 2 channel 200wx2 aamp. It was working just fine when I pulled it out of my old car 3 weeks ago.. I ordered a different output converter from crutchfield. It claims to work with high end factory stereos such as infinity/jbl/bose. I talked with a cust service rep and he felt confident it would solve my problem. if not Ive got 30 days to return it. The converter is a Scosche SLC4. I was previously attempting to use a stinger sloccii with no luck.
Reply
Register Home Page Forums Calendar Search Today's Posts Mark Forums Read
Tags
stereo or heater, working
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
[FX35] need help with car stereo! TinC FX Electronics & Lighting 4 11-09-2009 03:22 PM
[FX35] Intake for heater and a/c prelude48 FX35 - ('03-'08) 6 08-20-2009 07:35 PM
[FX35] Passenger seat heater not working Auburn_Fan FX Interior & Exterior 0 08-03-2009 08:48 AM
stereo system 1badfx45 FX Electronics & Lighting 1 10-06-2008 08:02 PM
working hard or hardly working...... hotmanali Chat Scene 50 08-27-2008 12:04 PM
© 2007-2010, InfinitiScene.com
Garage vBulletin Plugins by Drive Thru Online, Inc.
