[FX35] Axis and R1 Rims???? Cant decide - InfinitiScene.com
InfinitiScene.com
Go Back   InfinitiScene.com > FX Forums > FX Wheels & Suspension
Register Home Page Forums Garage Blogs Members Search Today's Posts Mark Forums Read
[FX Wheels & Suspension] FX Rims, Tires, Brakes, and Suspension.
View Poll Results: 22's or 20's
22's 9 56.25%
20's 7 43.75%
Voters: 16. You may not vote on this poll
Reply
Thread Tools
  #1
Old 02-05-2010, 08:33 AM
SanDiegoMarine SanDiegoMarine is offline
Ride: 2003 FX35 RWD
NewB Axis and R1 Rims???? Cant decide
Hello all! I am new to this forum, and i am really wanting to get Axis Penta rims, or the R1 racing Drift rims. i thought about going 20x9" in the front and 20x10 in the back. Will there be any problems with this? Also, im not sure what size tire to get as far as the tire height. I want good cushion, but dont want it to be too much rubber where it looks dumb. Also, i want to keep it around the same 18" diameter as the stock tire so i dont have any speedo issues. I am also getting the H&R springs put in before i buy the rims, so i dont want any rubbing. Anyone have any opinions on this? or issues? Where is the best place as far as prices to buy these rims? i have an 03 fx35thanks!!!
Register
Sponsored Links
Supporters do not see these ads. Click Here
  #2
Old 02-05-2010, 09:29 AM
theMerchant's Avatar
theMerchant theMerchant is offline
iS Supporter
RiSC: SCiS
Ride: 2005 FX35 RWD
Classified Rating: 100% (5)
Garage
welcome to iS .
in addition to what they posted over at the .ORG
I think they will look to small on the FX because of the lip design. but if you must get an offset around 15-20mm since stock is 40mm and is not flush with the wheel well.
as for tires you can go with 275-45-20 or 265-50-20 ... use the tire calculator located on the iS toolbar on top under 'Members'
  #3
909FX's Avatar
909FX 909FX is offline
iS Supporter
Ride: 2005 FX35 RWD
Garage
welcome to the scene. would you consider getting 22's?
  #4
Old 02-05-2010, 09:41 AM
Ride: 2003 FX35 RWD
yes i would consider it, since the other member saying 20s look too small. would they work with the lowered springs?
  #5
Old 02-05-2010, 10:01 AM
909FX's Avatar
iS Supporter
Ride: 2005 FX35 RWD
Garage
yes, pretty much majority here is lowered on 22's. Mine is lowered on 22's and I cut my front springs 1/2 a coil and no rubbing what so ever. I've taken my FX lowere, fully loaded up the Lake Arrowhead and no rubbing either.
---------- Post added at 10:01 AM ---------- Previous post was at 09:59 AM ----------
here is a pic:
http://www.infinitiscene.com/forum/a...&pictureid=564
  #6
Old 02-05-2010, 10:14 AM
Ride: 2003 FX35 RWD
wow thats nice! any pics of it stationary? i am doing the H&R springs. what size tires are best? what dimensions of rim on front and back did you get? thanks for any help!
---------- Post added at 10:14 AM ---------- Previous post was at 10:13 AM ----------
and yes, i see your sig. lol. i just wondered if you had anymore.....
  #7
Old 02-05-2010, 10:19 AM
gmgagne's Avatar
gmgagne gmgagne is offline
Ride: 2006 FX45
eibachs ftw! and i have lowered 20's and they look perfect to me! performance- 20's, 22's- looks
  #8
Old 02-05-2010, 10:48 AM
909FX's Avatar
iS Supporter
Ride: 2005 FX35 RWD
Garage
here is the most current:
http://www.infinitiscene.com/forum/showthread.php?t=477&page=44
  #9
Old 02-05-2010, 01:50 PM
Ride: 2003 FX35 RWD
no problems with lowered 35 with 22" rims? no rubbing? how about 265/40/22? not sure what the offset is
  #10
Old 02-05-2010, 02:08 PM
SexualChocolate's Avatar
SexualChocolate SexualChocolate is offline
Ride: 2004 FX45
I have 22s with 265s and lowered on H&R and it will work just fine. 22s look better (usually), but the 20s are much better performance wise (unless you go with a custom forged lightweight wheel). Even with the bikerack on (heavy IMO as it is a steel Sportworks unit) and 2 full suspension MTBs on there it doesn't tuck tire, so you'll be safe!
Depending on width the offset will vary. Some here are running as low as +15 their 22s, but I forgot how wide their wheels are and whether or not they are lowered.
  #11
Old 02-05-2010, 02:17 PM
gto's Avatar
gto gto is offline
Staff
RiSC: SCiS
Ride: 2005 FX35 RWD
Garage
I wouldnt say much better performance -wise. 22's handle really well. Just make sure you get a decent brand
  #12
Old 02-05-2010, 02:24 PM
Ride: 2004 FX45
Quote:
Yep that's true, possibly due to the shorter and stiffer sidewall. Straight line performance should suffer because of the additional weight and greater rotating inertial mass.
Ehhh something along the lines of this...
The equivalent weight of a wheel and tire assembly would be equal to the rotating inertia of that assembly divided by the square of the effective radius of the tire. (The effective radius is the distance up from the track surface to the axle centerline as the car launches.)
  #13
Old 02-05-2010, 02:43 PM
gto's Avatar
gto gto is offline
Staff
RiSC: SCiS
Ride: 2005 FX35 RWD
Garage
All true what you say.
Generally we all try to get the same Overall Diameter with rim & tire in the end whether 18,20 or 22.
That being said, the larger sidewall tire you have is gonna weigh more than the smaller. So there may be no savings in the end anyway. The larger tire with a smaller rim may even weigh more if you think about it. Also, Tires, even if the same model are not created equally either. A 45 vs. a 35 ratio is gonna be built really different. I think one has only to gain by going with the larger rim, & getting a better handling tire mated with it.
  #14
Old 02-05-2010, 02:45 PM
Ride: 2003 FX35 RWD
what about changing the speedo going from stock 18s to 265/40/22?
  #15
Old 02-05-2010, 02:57 PM
gto's Avatar
gto gto is offline
Staff
RiSC: SCiS
Ride: 2005 FX35 RWD
Garage
As long as you keep overall rolling Circumfrnce the same, the speedo stays the same. That's what everyone usually tries to achieve
---------- Post added at 02:57 PM ---------- Previous post was at 02:54 PM ----------
Lemme add, that I've sported both sizes. I didnt notice any diff in takeoff speed. Of course I'm just comparing to dead weight stockers.
The handling is far superior with the 22's & greater tire patch hitting the floor. Night & Day
  #16
Old 02-08-2010, 08:12 AM
Ride: 2003 FX35 RWD
ok decided to pull the trigger and buy the 22" rims from the guy in the classifieds. thanks for all your help in making me decide to get 22" instead of 20"! i think they will look nice on my silver fx!
  #17
Old 02-08-2010, 08:16 AM
gto's Avatar
gto gto is offline
Staff
RiSC: SCiS
Ride: 2005 FX35 RWD
Garage
& at least you wont regret getting the 22s after you buy 20s like most do.
What rim are you getting?
  #18
Old 02-08-2010, 08:47 AM
Ride: 2003 FX35 RWD
im buying the black and silver 22s from the guy in the classifieds
---------- Post added at 08:47 AM ---------- Previous post was at 08:47 AM ----------
should that size affect my speedo? 265/40/22
  #19
Old 02-08-2010, 08:58 AM
gto's Avatar
gto gto is offline
Staff
RiSC: SCiS
Ride: 2005 FX35 RWD
Garage
What ad? What rim & size? offset,width
  #20
Old 02-08-2010, 09:00 AM
Ride: 2003 FX35 RWD
not sure of the offset, but they came off a 45. look in the for sale under 22" black nitro rims. let me know what you think
---------- Post added at 09:00 AM ---------- Previous post was at 08:59 AM ----------
http://www.infinitiscene.com/forum/v...p?do=ad&id=311
Reply
Register Home Page Forums Calendar Search Today's Posts Mark Forums Read
Tags
axis, decide, rims
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
[FX45] axis wheels mjstriff FX Wheels & Suspension 1 01-26-2010 03:48 PM
22' Axis Titans on FX45 HumbertoCALI FX Wheels & Suspension 4 06-19-2008 03:40 PM
Nismo Badging: help me decide trainerKEN Chat Scene 11 07-23-2007 05:16 PM
© 2007-2010, InfinitiScene.com
Garage vBulletin Plugins by Drive Thru Online, Inc.
