#1
I haven't driven an SUV or crossover in a long time. Is it typical for the steering wheel to shake a bit when cruising at 50+?
| Sponsored Links |
#2
No it's not. How old are your tires? & may need alignment
#4
alightment and tire balancing
then you'll be good to go if it shakes when braking hard, its your rotors |
#5
#6
Thanks guys. That makes sense. I do have a bit of a rattle sound coming from the front/right wheel when I go over a really uneven road too. Does this sound like anything specific?
#7
lug nuts loose?
wheel hub bearings? |
#8
blown head gasket or crack'd block?
#9
bad alignment can cause vibrations? If so, this is good to know because I thought it was primarily rotor/wheel balance.
I thought alignment was more pulling to left/right/uneven tire wear. |
#10
I don't know guys. It doesn't shake when I hit the brakes hard or soft. The rattle sound does come from the right/front wheel. You guys think it may be a hub?
#11
#12
Quote:
#13
#14
Thanks a lot guys. The tires were brand new when I bought the car a week ago, so maybe the stealership cheaped out and didn't do an alignment. I will let you know what I find out.
#15
Quote:
![]() so yeah, find out |
#16
These cars are EXTREMELY sensitive to imbalance. I fought a vibrating steering wheel for over a year before finding a shop that could properly balance, though I still deal with occasional vibration from road imperfections.
#17
Besides some balance issues, does anyone have a clue what the rattle sound might be in my right/front wheel? Someone said a cracked engine block but I can't imagine.
#18
I would check the hub centric rings especially if wheels were recently off, probably need replacing.Also is inexspensive so would try first.
#19
Would I need hubcentric rings for stock wheels?
#20
nope,
Try getting them rebalanced, you can also first try rotating the rears to the front to see if the shake goes away. |
| Tags |
| shake, steering, wheel |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| [FX35] fighting the steering wheel | fxrider | FX Wheels & Suspension | 15 | 12-28-2009 04:24 PM |
| Steering wheel not level | erhan28 | FX Wheels & Suspension | 11 | 04-26-2009 10:48 AM |
| [FX35] Hissing from steering wheel | MASSIVE | FX35 - ('03-'08) | 10 | 04-01-2009 01:54 PM |
| Steering Wheel Play??? | 54fordcoupe | FX35 - ('03-'08) | 7 | 12-22-2008 01:00 AM |
| Steering wheel shaking | gunyhighway | FX Wheels & Suspension | 24 | 04-25-2008 07:51 AM |
