[FX35] Window rolls up then down. - InfinitiScene.com
InfinitiScene.com
Go Back   InfinitiScene.com > FX Forums > FX Interior & Exterior
Register Home Page Forums Garage Blogs Members Search Today's Posts Mark Forums Read
[FX Interior & Exterior] FX Interior and Exterior.
Reply
Thread Tools
  #1
Old 09-29-2009, 09:18 PM
Waleedalot Waleedalot is offline
MAINT Window rolls up then down.
I have an 05 Infiniti FX35. Window was broken and I had it replaced. Now there's a problem with the auto up feature. The window will roll up but when it closes, it rolls back a quarter of the way. If I don't use the auto feature, the window will not roll back when closed. The shop closed down so I'd like to do the repair myself.
Register
Sponsored Links
Supporters do not see these ads. Click Here
  #2
Old 09-29-2009, 09:49 PM
fxlr8's Avatar
fxlr8 fxlr8 is offline
Staff
Ride: 2005 FX35 AWD
Classified Rating: 100% (5)
Garage
Sounds like a possible problem with the pinch protection... maybe alignment or adjustment of the window.
  #3
Old 09-29-2009, 10:00 PM
jbaker1121's Avatar
jbaker1121 jbaker1121 is offline
Certified Snow Drifter
RiSC: NEFX
Ride: 2005 FX35 AWD
Garage
that happens if the battery ever dies... you ave to reset the window stopping-point thing but i totally forgot how to lol. search?
  #4
Old 09-29-2009, 10:11 PM
fxlr8's Avatar
Staff
Ride: 2005 FX35 AWD
Garage
Here is the limit setting procedure
Click image for larger version
Name:	window limit setting.JPG
ID:	1351   Click image for larger version
  #5
Old 09-29-2009, 10:13 PM
jbaker1121's Avatar
RiSC: NEFX
Ride: 2005 FX35 AWD
Garage
that's what i was looking for...good luck!
  #6
Old 09-29-2009, 10:28 PM
theMerchant's Avatar
theMerchant theMerchant is offline
iS Supporter
RiSC: SCiS
Ride: 2005 FX35 RWD
Garage
nice
  #7
Old 09-29-2009, 11:22 PM
Thanks guys did it.. took only 10 mins to fix...
  #8
Old 09-29-2009, 11:31 PM
Dr.2K's Avatar
Dr.2K Dr.2K is offline
iS Doctor on Duty
RiSC: SCiS
Ride: 2005 FX45
Garage
Cool. This deserves a DIY thread.
  #9
Old 09-30-2009, 01:10 AM
dopie's Avatar
dopie dopie is offline
SOOOWOOOOP!!!!!!!
RiSC: SCiS
Ride: 2006 FX35 RWD
i had this happen to me when i got my window broken into.
the body shop ordered aftermarket window, and the window was a lil degree off then the oem ones and that happend. so they ordered me a factory window and it works find.
and second it can be the regulator that is missed up also.
  #10
Old 10-08-2009, 02:51 PM
Deecarp's Avatar
Deecarp Deecarp is offline
IS Resident Dark Wagon
RiSC: NCiS
Ride: 2003 FX35 AWD
Quick question on this procedure. Do you have to remove the inner door panel (metal panel with about 8 screws) to get to the reset switch. or is it something you can get to after removing the outer door liner panel (interior panel w/window switch).
  #11
Old 10-16-2009, 07:21 PM
Deecarp's Avatar
RiSC: NCiS
Ride: 2003 FX35 AWD
OK I did this procedure today after being annoyed with the window not rolling up properly, after repairing a door handle. after removing the door panel you'll find the reset button at the center of the door covered by a small circular piece of vinyl. uncover the reset button, follow those procedure in Jeff's pdf DIY post #4 of this thread and your done.
  #12
Old 02-09-2010, 12:10 AM
angus angus is offline
Ride: 2005 FX35 AWD
OK , did my driver door today , had a problem since installing the weathertechs , had to do it a few times to get it right . We shall see if it works long term...
  #13
Old 02-09-2010, 07:00 AM
Deecarp's Avatar
RiSC: NCiS
Ride: 2003 FX35 AWD
It's been a minute now since doing mine and it still working fine
Reply
Register Home Page Forums Calendar Search Today's Posts Mark Forums Read
Tags
rolls, window
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
[FX35] do you use the window deflector on your FX ? hangout FX Interior & Exterior 19 09-09-2009 03:06 PM
Automatic Window KFL2006 FX Interior & Exterior 2 05-11-2009 07:40 PM
Window Tint JimmyZ FX Interior & Exterior 17 05-01-2009 03:32 PM
Window tints? gunyhighway FX Interior & Exterior 11 06-03-2008 03:36 PM
Window treatment... FX_Allen FX Interior & Exterior 20 02-24-2008 11:37 AM
© 2007-2010, InfinitiScene.com
Garage vBulletin Plugins by Drive Thru Online, Inc.
